Rocky Bronco
@Felix 808 - Count this FE in if you got room for one more!
I like my Midland MXT575 because it allows you to remotely mount main unit because all the controls & speaker / mic are on the handset.Hey Guys, too many choices... what GMRS radio do you suggest?
I would suggest starting out with an inexpensive hand held. They are plenty good enough for staying in communication while on the run and don’t require a huge investment. If you want to keep it super simple and just want to stick with GMRS, then something like the Baofeng GM15 Pro is a good options. You can get a pair of them for about $50 on Amazon. If you’re willing to do a little programming, and want something that can do both 2-meter and GRMS then something like the Baofeng 5RM or similar might work. Note that if there are more than one of you in the Bronco, I would invest in a pair so guys can communicate if you’re not both in the Bronco at the same time. For example if one of you is driving and one is spotting.Hey Guys, too many choices... what GMRS radio do you suggest?
Shouldn't be too much of a problem and if it is we'll work through it with the right attitude. Most of the trail is really easy. There might be 1 or 2 spots where we might have to work through something. Expect some pinstripingThink it can be pulled off with a 78, no traction device, no lift?
Count me it then!Shouldn't be too much of a problem and if it is we'll work through it with the right attitude. Most of the trail is really easy. There might be 1 or 2 spots where we might have to work through something. Expect some pinstriping![]()
Anytime Tomrequesting permission to come aboard, Tom, white 2dr badlands
Look forward to seeing you guys again.@Felix 808
Hey, we'll join you! Only ran White Mountain once many years ago.
THANKS!I would suggest starting out with an inexpensive hand held. They are plenty good enough for staying in communication while on the run and don’t require a huge investment. If you want to keep it super simple and just want to stick with GMRS, then something like the Baofeng GM15 Pro is a good options. You can get a pair of them for about $50 on Amazon. If you’re willing to do a little programming, and want something that can do both 2-meter and GRMS then something like the Baofeng 5RM or similar might work. Note that if there are more than one of you in the Bronco, I would invest in a pair so guys can communicate if you’re not both in the Bronco at the same time. For example if one of you is driving and one is spotting.
You got it. This will be a great run for you@Felix 808 If there is still room, can you count us in? We are newbies! It would be nice to ride with some experienced fellas!
We are in a Bronco Raptor.
You just made it.Felix, If you have room, Please add Larry Barnes Green 6G. Thanks for leading.
You are the last. I'll be off the air, so we'll see you all in Big BearHello, If someone withdraw, I'm in ! Else I will join another group medium difficulty. Thanks !
