What is the "GO TO" transmission swap?
dkutz
So my buddy's 70 Bronco has a Manual Transmission. He hates it. And wants to switch to an Automatic. What would everyone recommend? C4? C6? AOD?
It will be a street driver for the most part. Maybe some of road but nothing hard core.
Suggestions?
Sounds like he'd be best off with something with overdrive. Either AOD or AODE (4R70W) are highly regarded, as is the 700R4 if you're not averse to putting bowtie parts in it.
4R70W with a Baumann controller is a great combo. The later models have the important upgrades. 4x4 model is easiest to work with. ZF adapter and crossmember with mods is good for Dana 20 or upgrade to Atlas.
If you're going to spend the money on a trans and a controller I'd take a good look at the later 6R etc. transmissions.
