12-Pack Jeff
I finally pulled the trigger on Duff Long arms. You know, so I can hang out with the cool kids again. (Now I just need 40's)
Reading through the instructions it says "This kit will not work on vehicles with less than 3.5" suspension lift" I assume that's a C.Y.A. statement to avoid a flood of questions when installing on a vehicle with less lift.
I looked through older posts on CB on the topic, many said "I installed it on 2.5 and it works fine" but they were mostly if not all from mall crawlers. The only concern seemed to be the degree bushings for the caster - but there were no negative responses.
Only negative I can come up with, aside from caster adjustment is limited up travel. Is there anything else I'm missing?
I'm not sure if I've got 2.5 or 3.5 coils, they're probably 15-20 years old and the part number is long gone so I'm left with guessing and trying to prepare for possible next moves.
Two last questions -
Do you guys limit strap your front axle w/ long arms? If so, how did you mount them?
I got a killer deal on some beefy custom made bump stops - any good suggestions where to mount them on a stock D44 w/ Long Arms?
If anyone wants a set of bumps let me know, I can put you in touch with my friend.
