Has anyone setup their Bronco to be flat towed behind a motorhome? Interested in your setup. Also can I use the recovery points in the front to tow?
Thank you Dusty.I have. And yes, if you have the mod bumper, or any aftermarket bumper that has d-ring tabs for recovery points, yes you can attach your tow bar to them.
I have also. I initially bought the rough country tow hook brackets for that reason since I opted for the basic plastic bumper. I ended up getting the LOD offroad bumper sooner then I expected. They have d ring tabs on it and frame stiffeners. They even say it's approved for flat towing. Even though that doesn't really mean anything.Has anyone setup their Bronco to be flat towed behind a motorhome? Interested in your setup. Also can I use the recovery points in the front to tow?
Thank you. Your response was super helpful. It lead me to the roadmaster 035-1. If my measurements are correct this will fit perfectly on the stock ford modular bumper recovery points.
They make 2 sizes. My EB is a different size than my 6g.Thank you. Your response was super helpful. It lead me to the roadmaster 035-1. If my measurements are correct this will fit perfectly on the stock ford modular bumper recovery points.
