Kelly's "Mr. Toad's Wild Ride" build specs
Kelly Nisley
'75 Bronco
Bought in 2004 from Angelo Sabadin in Monterey Park. It was in Santa Barbara before then.
351W
GT40 style heads
Holly Truck Avenger 650
Weiand Stealth Intake
14"x4" air cleaner
Duraspark II module and distributor
Holley Offroad Coil
Odyssey Extreme AGM battery relocated to rear
WH/JBA ceramic coated shorty headers
Custom 2 into 1 exhaust with Flowmaster 40
Tri-Flow baffled copper/brass radiator
Stock fan with aftermarket shroud
Stock iron water pump
Hydroboost brake system from a van
'76 Slotted/dimpled front rotors
Rear disc conversion from '98 Explorer with Currie spacer ring
C4 Transmission built by me using Broader Performance upgrades
Large Derale stack plate cooler with fan
Small Derale stack plater cooler in front of radiator
Dana 20 transfer case
JB Fab twin stick
WH heavy duty full spline driveshafts
Dana 44 front end
Yukon chromoly axles
Gold u-joints
Detroit Locker
4X Doctor rock guard
Ford 9" big bearing rear end
Currie chromoly axles 32 spline
Detroit Locker
Custom thicker housing
Rear truss
Great Lake Offroad pinion guard
Custom anti-wrap device
Stock '76 power steering box
Delphi pump with WH bracket
Cooler with fan
Stock pitman arm
4X Doctor custom track bar riser with bump stop
4X Doctor custom track bar frame mount
Stone Crusher Steering drag link and tie rod
GM Blazer K5 TRE
Heim joint track bar
35" ProComp Xtreme M/T tires on 15" steel rims
2" body lift
Hood scoop
"Toad Legs" custom extended radius arms with 2" chromoly tubes bent for wheel clearance and 1" HD heims
3.5" front WH progressive springs
Bisltein 7100 14" short body shocks
4X Doctor custom shock mount that goes from frame to top of spring perch
5" BCB thick leaf rear springs
Custom 1" extended spring hangers
Custom HD rear spring perch
Bilstein 5150 12" short body shocks
JD rear shock mounts in front of axle
BCB 23 gallon fuel tank with skid plate
Holley external electric pump
Custom front bumper with removable winch mount that can move to the rear hitch
Tuff Stuff Xtreme 12,500lb Waterproof Winch with Synthetic Rope
7/8" shackles
Two HID offroad lights
12" light bar on top of winch
Yellow fog lights
Custom rear bumper with hitch mount
7/8" shackles
Custom tire carrier using spindle hub hinge that carries tire, Spectre water can and gas can, Hi-Lift jack, axe, shovel and big cooler
Rear LED lights
3rd brake light
Custom license plate
Custom family roll cage, 2" tube with taco gussets, floor tubes with seat mounts, front and rear grab bars, attached to frame
Locking storage compartment under seat
Map light from a tank/APC
Airline style lights
CB speaker
Curved racing mirror
Custom 2x6" rock slides, frame mounted
Custom tube doors with clear Lexan panels
Custom removable vinyl windows
BroncoDesign roadster door inserts
Rampage/STC soft top
Custom rear locking tool box behind seat
PRP Daily Driver Seats with wide and tall option
Crow Racing Products and Tanaka 5 point harnesses, duck bill latch
Tuffy Products glove box and center console
Custom LED headlights with cooling fans
Custom LED rock lights and interior lights
Custom front and rear cup holders
Passenger cooling fans (NASCAR brake fans)
12V power ports front and rear
Pioneer radio and two Pioneer compact amps
Four Infinity Kappa 6x9" speakers
Two Baofeng radios and rear Tram 1180 antenna
