I'm in the middle of one. Some of the things that I've learned:
With a LOT of fabrication work it is possible to include the '96s ABS sensor up front, but after several nearly bad experiences off pavement I'm ditching the whole system. This is too bad because I think it is a good system to have on pavement. Can think of it as a smart proportioning valve that is able to automagically compensate for different loadings. However, it is not smart enough to handle dirt use very well. I tracked down a Stewart Components LBS to use if it proves necessary.
Looks like you can transplant the GM 3/4t D44/10 bolt front 8 lug outer assemblies to a TTB with 6 bolt knuckles. Early and late (4WABS) TTB's have 5 bolt knuckles and these won't work. I have not investigated what it would take to make them work. You will need at least 16" wheels to clear these rotors, 15's will NOT work*. For the GM 8 lug stuff to fit you need from the donor:
Caliper brackets
Stub Spindles
Wheel hubs
Rotors
Outer axle shafts
To clear the caliper & GM bracket the knuckle needs to have the cast-on caliper bracket completely removed.
The GM caliper bracket needs a slightly different clocking than where the OEM holes place it. A second set of holes between each of the existing are required.
I will update this thread as I learn more.
*Do not talk about grinding on the calipers to make them work. Anyone who does that is a fawking idiot!
Caliper brackets
Stub Spindles
Wheel hubs
Rotors
Outer axle shafts
