jim@wildhorses4x4
Finally broke some stuff. Mitch and I pre-ran Prison Hill OHV in Carson City for Super Cel Nevada. Check out the event info here.
www.broncodriver.com
I heard some sounds reminiscent of classic Bronco front axle explosion. Nothing exploded but my 4WD shut off so we headed out. Slow left turns had a very good, or bad POP! Sure enough the driver side CV outer had issues (M210 4.70) Found the problem right? Not so fast. We noticed some random noise and stuff that just didn't feel right coming from the front end after changing the driver CV axle. Turns out we broke the intermediate shaft as well. So we're in the middle of a portal install (totally different story) that turns into a FDU tear out because the axle is just not coming out. Here's the piece that was stuck in the diff. Needless to say we are learning a lot about these new Broncos.
Pro tip: put Bronco on lift, engage 4WD low, lockers on, make sure all 4 tires are spinning.
Pro tip : you have to cut the bearing off on the electro mag side of the diff to take apart the locker.
Hope to see some of you in Carson City. Happy wrenching!
Jim
— Bronco Super Celebration (Nevada) | Bronco Driver
Jim
